what fuelpump
  • Jeffer
    • 2057
    what fuelpump
    I'm going for big injectors
    But that means I need a big fuelpump aswell. What is suggested by you guys? And will I need another pressure regulator on my fuel-line?
    Thanx
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
  • Doug_RS2
    • 3847
    Bosch Motorsport fuel pump: 0580 254 044
    200lt/h @ 5bar fuel pressure
    Mark originally fitted this and I copied.
    Mark has a Bosch Motorsport FPR: B280 550 113
    Link
    He is using this with RS2 injectors. I am going to use the standard FPR with even bigger injectors.
    You can modify the standard FPR - basically stick an air line on the inlet and measure the outlet. In a vice or with a ball-joint-seperator squeeze the top of the FPR until you get an increase in pressure - a 4 bar might not measure 4 bar with air but an increase of X (standard to what you want) bar should do the trick.
    HTH
    • Jeffer
      • 2057
      Thanks Doug,
      Do you know anything about pricing?
      High Octane website
      • Doug_RS2
        • 3847
        Link to Uk Fuel Pump Distributor
        I got the fuel pump from here. Their online webpage says it is £180+uk vat.
        If you email them to get a price first, it is £145 +vat
        The 5 bar FPR was coming in around £130. I can't remember if that was +vat or not but it also has a 3-4 week leadtime on it.
        HTH
        • Doug_RS2
          • 3847
          And you need the parts to fit that fuel pump - it's in the projects section, in the 420+bhp thread.
          • Jeffer
            • 2057
            Ok thanks,
            Going to search for a dutch distributor.
            High Octane website
