RS2 cross member
  • Martynf
    • 1885
    RS2 cross member
    Seeing as we had a RS2 cross member in today (not every day that happens at £800 each!!), thought I'd snap a couple of pics of it. One interesting thing I noticed when moving it about was that the IC tube inside was loose, IE not fixed and also it was made of plastic!!! Kinda resembles the Plastic top pipe posts a while back about plastic and less heat soak.
    Martyn
    www.vagparts.com
  • Martynf
    • 1885
    Martyn
    www.vagparts.com
    • Martynf
      • 1885
      Martyn
      www.vagparts.com
      • Martynf
        • 1885
        Martyn
        www.vagparts.com
        • Martynf
          • 1885
          The SFS silicon hose mod would work a LOT better on this than the stock S2 pipe which is curved where the top clip goes. Trouble is, this X member is just way too much money! shame...
          Martyn
          Martyn
          www.vagparts.com
          • Martynf
            • 1885
            close up:
            Martyn
            www.vagparts.com
            • Doug_RS2
              • 3847
              Could you not modify the bracket on your crossmember and send that out by mistake - they would never know
              I didn't think mine was plastic - maybe it's just the newer ones?
              • s2avant
                • 2426
                They're not too expensive Martyn
                On a more serious note, mine has got the plastic tube instead of metal.
                Ben
                • Martynf
                  • 1885
                  :-) could do Doug, but I think QS would notice that!!!
                  Ben did you wrap yours in suasage foil?
                  Martyn
                  www.vagparts.com
