Seeing as we had a RS2 cross member in today (not every day that happens at £800 each!!), thought I'd snap a couple of pics of it. One interesting thing I noticed when moving it about was that the IC tube inside was loose, IE not fixed and also it was made of plastic!!! Kinda resembles the Plastic top pipe posts a while back about plastic and less heat soak.
RS2 cross member
:Attached Files -
-Attached FilesComment
~Attached FilesComment
The SFS silicon hose mod would work a LOT better on this than the stock S2 pipe which is curved where the top clip goes. Trouble is, this X member is just way too much money! shame...
MartynComment
close up:Attached FilesComment
:-) could do Doug, but I think QS would notice that!!!
Ben did you wrap yours in suasage foil?
