Hi
Have pulled fault codes with Vag com and this one came up:
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
have searched the Ross-tech site, all I found was some problem the regarding airbag controller.
The car is a 3B (no airbag obviously), and the code comes each time I restart the engine. Does this code mean my ECU is damaged?
Or is it normal, btw my car is chipped. It's running ok, except for some hesitation now and then.
Cheers Leif-Helge
1 Fault Found:
00-00 - -
Or is it normal, btw my car is chipped. It's running ok, except for some hesitation now and then.Cheers Leif-Helge
