1.9 TDI WGCFV Permanently Clicking?
  • Glen Chamberlain
    • 375
    I have been asked to investigate a lack of performance problem on an old K plate 80 1.9 TDI and I have noticed the WGCFV is permanently clicking with the ignition on and/or the engine running. Drives like it has no boost (not checked but stands to reason with the clicking in my mind?) which makes it unbelievably slow!
    Cant read the ECU because I need a genuine Vag-Com interface so I am in the dark a little? He managed to get the ECU read a while back and this is what was found:
    00552
    VOL AIR FLOW VAF SENSOR G19, INTAKE, EGR SYSTEM HOSE CONNECTIONS. WIRING TO SENSOR
    00523
    INTAKE TEMPSENSOR
    00519
    MAP TO WASETGATE REGUALTING VALVE HOSE CONNECTIONS POOR CONDITION WIRING TO MAP SENSOR ECM UNIT.
    Problem is the guy that read the ECU says his system cant delete the DTC's so I have no idea how old or relevant they are?
    Any ideas please?
    Money is everything! Second to Power of course!!! But money breeds power??
  • audiman
    • 4827
    Disconnect the battery or unplug ECU for a few minutes, that will clear them. A faulty WGFV wont make it click all the time, and it gets its signal from the ECU.
    My suggestion would be to clear codes, check they are gone then drive it and then re-check the codes.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Glen Chamberlain
      • 375
      The guy that check the ECU said he disconected it for 5 ins but the codes didnt erase? Faulty ECU?
