i bought a set of injectors fro the us, i was told that they was mached... Anyway i tested them in a bosch flow bench,,, and i was happy that i havent mounted them in my engine..
have anyone tested their injector flow???
Are they Bosch injectors? If so, then what is the part number on them?S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!Comment
The spray pattern doesn't look good, very incosistenetS2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!Comment
SO are they matched then ? How many cc's per minute at 3bar fuel pressure ?
Been wanting to build a wee test rig like that for a while - but like most things automotive it will have to wait....
PaulPaul Nugent
no they are from venom. i recived a new set today but 4 of them was leaking but the flow was beter.. but any way i cant use them.. have to send them back. and by other injectors.ABT C5 Lord Of The Rings
2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
kostic.nuComment
no they are not.. they shuld spray 788ccOriginally posted by S2central.netSO are they matched then ? How many cc's per minute at 3bar fuel pressure ?
Paul
it was 40ml difrence .ABT C5 Lord Of The Rings
kostic.nuComment
yes.. but now i am going to byr other ijectors fom my lockal deler.. an i am going to mach them my self.. they orded a chart with 100 injectors. (not venon)ABT C5 Lord Of The Rings
kostic.nuComment
788ccpm at 3bar - WOW thats a lot of fuel - good for 750bhp if youve got fuel pump(s) man enough to handle the flow. Gunk - surely you can't need injectors as big as this ?Originally posted by zlobono they are not.. they shuld spray 788cc
PaulPaul Nugent
Thats correct Paul. I dont need so big injectors any more.. i thught i shuld run my engine on ethanol befor but now i am back to run it on petrol so i am going to be happy with 530-630ccOriginally posted by S2central.net788ccpm at 3bar - WOW thats a lot of fuel - good for 750bhp if youve got fuel pump(s) man enough to handle the flow. Gunk - surely you can't need injectors as big as this ?
Paul
and when u run it on ethanol you need atleast 30% more fuel tu make it run at lamda 1.ABT C5 Lord Of The Rings
kostic.nuComment
I run on ethanol as we have it on the gas station as a standard fuel in Brazil.
My injectors are +- 42% bigger than the RS2 injectors, and on 2 Fuel pumps in the tank with 2 lines and one filter for each line. Also I have cold start system, that is started by a temp sensor, as ethanol do not burn in temps below 14º C. At least is very diff to start in the morning without the cold start system in winter, I'm sure that your winter is colder than mine in Brazil...
But i got to say that is a big diff in ethanol as you can get the ignition map much more egressive.S2 Limo sold !!!
M5 E34 with some mods in the garage
sorry, but much happeir now !Comment
