have anyone tested their injector flow???
  • zlobo
    • 967
    Originally posted by S2sedan
    I run on ethanol as we have it on the gas station as a standard fuel in Brazil.
    My injectors are +- 42% bigger than the RS2 injectors, and on 2 Fuel pumps in the tank with 2 lines and one filter for each line. Also I have cold start system, that is started by a temp sensor, as ethanol do not burn in temps below 14º C. At least is very diff to start in the morning without the cold start system in winter, I'm sure that your winter is colder than mine in Brazil...
    But i got to say that is a big diff in ethanol as you can get the ignition map much more egressive.
    i know... dont you have an problem with the brether? that is coming out pure ethanole from there when u get 70 degrece celsius?
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
