The other thing is my injectors could be clogged a bit. I thought I read that they could be cleaned. I tested them according to the Bentley and they were all ok. But they could still be partially plugged... and new ones are way too much.
Maybe it's time for the 02 sensor/s to be replaced, i remember reading a while ago now that audi reckon on 60kmiles is about it, i wouldn't mess around with generic ones buy bosch or oem.
Could be cats collapsing or silencers blocking causing back pressure? worth a try. Did an Zetec last week that had cat gone and wouldn't run due to too much back pressure. Worth a try.
chris
A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
My brother's 80q had similar issues. Two new lambda probes sorted it. Also both of the headgaskets had failed - quite common on the early 12v. Have a look at http://www.12v.org/
You guys are awesome thanx for the help... I well check them out.
I also had the cats replaced about a year ago with hi flow ones, not to say its not the problem.
I replaced the coil-packs today and it runs a lot better. The car still drops a little RPM's at idle... I was thinking this could be because my sub amplifier draws a lot of power or it could still be something else but at least it drives good now.
