fuel leak help!
  • stevieyid
    • Apr 2005
    • 2251
    fuel leak help!
    Hi just when i have been doing loads of overtime to get my remap from mrc tuning and what happens i see fuel leaking from what seems like a clip where i think the three fuel lines run through. i got a pic but how do i download it onto here? If one of the fuel lines is this a big problem or is it a quick fix
    3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
  • stevieyid
    • Apr 2005
    • 2251
    i found out how to upload the pic. anybody got any ideas from this of what it could be?
    • BRY
      • 3755
      The fuel pipes on these cars are old and have been known to leak at this age. You will have to replace them, you might aswell do them all while you are at it.
      • Doug_RS2
        • 3847
        This is a common problem. I just finished repairing an S2 yesterday with this. THe rubber mounts hold the water and so the pipes rust inside the rubber.
        The proper way to fix it would be to replace all of them. If you want to just cut that section out you can do, and replace with a short section of rubber fuel hose. If you do this - remove all the metal clips along the length of the hoses under the car as you will probably find another part will start leaking if you force the metal pipes.
        The clips are a bit fiddly - use a screw driver in behind the fixed part of the clip(between the clip and underside of the car) to stop it moving - then another screwdriver to push the other half out. Hard to describe!
        HTH
        • stevieyid
          • Apr 2005
          • 2251
          Just making sure they are the fuel lines in the pic i have put arent they? Does anyone no how much they would be to replace? if they are to dear i will do what doug said as a temporary measure until i have had my remap done. thanks for your help
          • porkkis
            • 1994
            The lines are around 100€ each.
            • stevieyid
              • Apr 2005
              • 2251
              any body no where i can get these fuel lines from in the uk and how much they are over here?
              • rotoryboy
                • May 2004
                • 3281
                The best so far seems to be microbore central heating pipe
                Mark
                Race Clio RS197
                S2 Coupe ABY (Green) - RIP
                S2 Coupe ABY (Blue) - Sold
                • Jas11n
                  • 5067
                  Yep, just done mine 2 weeks ago. Do as said above and do the lot, don't mess around replacing a little bit as you'll find yourself back under in a week or two.
                  I went to my local plumbing centre and got hold of some stainless steel microbore heating pipe and completly replaced the whole three lines visable under the car.
                  Cut them at the front where the lines emerge from the heat shielding and at the back where they drop down in front of the rear diff.
                  Used some fuel injection grade rubber hose to join the new pipe to the old, and most important of all, used proper hose clamps not jubilee clips.
                  Now the underside of the car has "bling" fuel lines
                  2001 Avus Silver B5 RS4.
                  1995 S2 Coupe - sold (sniff)
                  • stevieyid
                    • Apr 2005
                    • 2251
                    hi thanks for your help i will use the heating pipes. how much did the pipes cost you? where shall i get the hose clamps and rubber hose from? do vag do them
                    • Jas11n
                      • 5067
                      I payed a tenner for the pipe, but I know a guy who works there, so not sure on the normal price, sorry.
                      I got the hose (dunlop fuel injection hose) and hose clamps from good old halfords.
                      They had a selection of different size hose, so I just took the stainless steel pipe into the store with me and got a size that was a nice tight fit.
                      HTH
                      Jas
                      • stevieyid
                        • Apr 2005
                        • 2251
                        Hi got some microbore pipe in the garage which is coated in rubber. Do these fuel lines get very hot? Im just worrried if use the rubber coated lines the rubber will melt. Also would i need some high pressure microbore pipes or do these not exist?
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          Oh, Jas!! Blinging up the underside of your car now?!
                          SS
                          • Jas11n
                            • 5067
                            I used rubber fuel injection pipe on the previous 2 coupes (not S2's but very very similar underneath pipe wise) and never had a problem.
                            My reason for this time using a solid pipe instead of the rubber, was that previously I couldn't get the rubber pipe to go through the rubber hangers without taking them off and reaming them out, bit of a PITA both times. I could have just used normal copper microbore piping but thought stainless steel was the better option seeing as my mate works at the plumbing suppliers and I could get either for next to nothing.
                            Not sure what spec the rubber coating on the pipe you have is Steve, for peace of mind I'd rather use a solid line, good spec fuel injection hose or even the real deal from either vagparts or the stealers. I can't see the pipes underneath being subjected to that much heat, but, as the saying goes "**** happens" (hmmm, and don't I know it ) I'd use either a solid metal line or pukka fuel injection hose, just to be safe.
                            Nothing wrong with a bit of "bling" Stu
                            • stevieyid
                              • Apr 2005
                              • 2251
                              Hi i went to halfords tonight for the fuel hose and to see what how much it was. I was just wondering what size hos edid you buy? Was it 8mm? just want to make sure before i waste my money. Also i have decided to buy the steel microbore pipes do they only come in 8mm?
