Fault code 00537 = faulty lambda or bad sparks?
  • Jonas_R
    • 3780
    • Country: Denmark
    Well i get fault code:
    00537 - Lambda (Oxygen Sensor) Regulation
    11-10 - Control Limit Not Reached - Intermittent
    It seems that my car suddenly drives really rich in low rpm's and car cant keep going. It dies in the low RPM.
    Iam thinking bad lambda (1 year old), perhaps bad sparks? or perhaps bad fuel filter?
    Any other suggestions?
    Sparks are 2 years old and has driven 30.000 km, is standard 3b oki?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • porkkis
    • 1994
    Fuel pressure reg or somehow blocked return line?
    • Jonas_R
      • 3780
      • Country: Denmark
      Why do you say this porkkis?
      /Jonas R.
      • porkkis
        • 1994
        Isn't it obvious?
        • kwlw
          • Sep 2004
          • 1025
          • Country: Lithuania
          Originally posted by porkkis
          Isn't it obvious?
          It can also be pressure hose, which "tells" fuel pressure regulator, what pressure is in IM. It is rubber, maybe it is cracked ?
          I mean hose from IM to the pressure regulator. Check it.
          Sau
          • Jonas_R
            • 3780
            • Country: Denmark
            Isn't it obvious?
            Nah not really
            Any way to check fuel regulator and return line?
            kwlw:
            Just changed that hose, so that should not be the problem, and i can still get full boost. If that hose were cracked there would be air leaking.
            /Jonas R.
            • porkkis
              • 1994
              Too much fuel pressure -> rich.
              Get a 0-5 bar gauge and double banjo for the fuel rail (3B) and measure it. It should be 3 bar with engine turned off and fuel pump running. You need a jumper wire to replace the fuel pump relay.
              • Uukrul
                • Aug 2004
                • 23
                /Jonas R.
                sparks (F5DPOR ones) should last at least for 60.000 km.
                Disconnect your lambda and see if it resolves low RPM problem. When lambda is disconnected ECU should use "failsafe" defaults - a little bit rich, but engine should not die in low RPMs.
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  Disconnecting the lambda, can i do that by unplugging the black cord and the two white cords?
                  /Jonas R.
                  • porkkis
                    • 1994
                    White ones are for heating so you can leave them connected.
                    It's the single wire for the signal.
                    Word of warning. Do not let the signal wire touch car chassis or anything when the exhaust is warm. This will kill the sensor.
