Paul N - You may need to change the S2 Central aby ecu codes description for '2224' - it doesn't just misfire on wide open throttle, but on anything resembling 1/3rd throttle!
Coughed and spluttered my way onto the motorway at the heady speed of about 50-60mph in 5th. (I was following a 1.2 corsa and struggling to keep up - and she wasn't even trying :S).
So, which pipes are best to start with, anyone? The WGFV was changed last year, and someone please remind me again - what's a J220? Air flow meter?
I did change the clip on the black metal pipe ---> throttle body last week/week before and no problems till today - put old cacked up clip on again now, so I'll see if that caused it (have cleared fault code). Otherwise is it 'remove anything resembling a rubber pipe and check for leaks'?
Cheers, Paul J
Cheers, Paul J
