RS2 Intecooler
  • NorrS2
    • May 2004
    • 210
    RS2 Intecooler
    Folks
    Just got hold of a new RS2 Intercooler.
    1. Can anyone tell me if this will enhance performance (car has homefry)?
    2. Can anyone point me to a thread that tells me what I need to fit it?
    Cheers lads
    95 S2 Avant Ming Blue - now gone and sorley missed:cry:
    2001 B5 RS4 Santorin Blue - MRC'd - now here:chit:
    88 Ur MB Quattro -Pearl White - The daddy!:cool:
    Classic S2 Avant billboard ad - "My other car's a Porsche, but today I'm in a hurry"
  • s2avant95M
    • 1217
    • Home: England Current: United States
    you will need an RS2 crossmember or failing that some welding is needed. there are threads on this if you do a search.
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
        Colder air will result by way of the RS2 intercooler, so there is definitely a benefit - again unquantified in isolation on a chipped car. If you have VAG-COM it would be useful to log intake air temps on WOT runs before and after fitting the RS2-IC. From that we can estimate the theroretical additional power made possible by the (hopefully) colder air.
        Paul
        • S2Roo
          • 191
          Hi peeps,
          I hope this isn't construed as off topic but.......
          Is there an optimal size of intercooler? Surely a larger intercooler must contribute to some delay in pick up time as the intercooler has to fill before the air can be forced into the engine? Is there an optimal trade off between heat reduction, and time to fill the intercooler?
          S2roo
          • Henka
            • 585
            • Home: Sweden
            Yes there is. It is related to the turbo, EM, IM, mapping etc. It is very individual in the sense that all the parts of the engine has influence in the need of IC capacity. I'd say that as small as possible is way to go. Now, in my book "possible" means without any loss in perofrmance. A bigger IC will give you lag period. Yes, a bigger IC will/might/should cool the air more but the effect it has on overall efficency and running of the engine is not that clear. By stating this I guess there will be alot of opinions.
            The only way to really know is to check temp before and after the IC. Too hot --> go bigger or more efficient. Low? Maybe you can go down a bit. All this testing takes time and money but if you start with a S2 ABY, then go RS2 you pretty soon see what you need... That is the right way to do it. Most peaople just check auto magazines, see a car with an IC the size of barndoor and just buy one just like it.
            • audiman
              • 4827
              Can the intake air be too cold then?? I would have thought the colder the better, maybe its not as critical in colder climates like in Sweden??
              Tom C - www.rcmr.co.uk
              Audi UR Quattro
              Audi 100 C3 2.0 5 cyl 115ps
              Audi B5 RS4 645ps 911nm
