Hi all,
Have just joined the club and got myself a RHD RS2, with 86k on the clock. Having now done most of the bulbs on the dash, it's now time to address the problem of performance.
At the moment it just doesn't have that the kick in the back that i found in others when the turbo kicks in and I want to get the most out of the beast.
Work done so far: Cam belt changed about 6 months ago by previous owner, spark plugs and air filters changed. I had the car booked in with QST who told me that most performance problems are cause by air leaks, but couldn't make it down in the end.
I am currently in Milton keynes so if anyone knows of someone suitable nearby... Especially as i have recently read some mixed review of QST(not to mention the long drive), not sure if this would be such a complex task requiring their expertise?
Sorry for the ramble, but if anyone can suggest a course of action would be very helpfull.
Rich
At the moment it just doesn't have that the kick in the back that i found in others when the turbo kicks in and I want to get the most out of the beast.Work done so far: Cam belt changed about 6 months ago by previous owner, spark plugs and air filters changed. I had the car booked in with QST who told me that most performance problems are cause by air leaks, but couldn't make it down in the end.
Rich
). Only thing left to do is to replace the vacuum hoses that feed the ECU and boost gauge with silicone hose to complete the job. It's well worth putting the time and effort into sorting the high pressure inlet. This may not solve all or even any of your problems but for relatively little money it does remove any doubts when fault finding and give total peace of mind that when you need it the power will be there. AND the Samco hoses look the Mutts Nuts!
