Hi Everybody,
Seems eventualy I got rid of boost leaks. ( My opinion)
Now I had a strange behavior of with fueling.Will try to explain:
I got A/F meter fitted inside dashboard. When I drive normaly without sudden "pedal to the metal" the A/F ratio (lamda) shows (most times) about 1, which is normal.
As soon I push it hard-the boost goes to 0.8bar, but A/F lights goes down and disapears-no readings. There is no boost cut out, just strange pulling power. I trying not to push hard in case A/F mixture goes lean.
Could be faulty MAF, Temp sensor on top of IM, or fuel pump?
Any suggestions?
Of if anybody in NW area can lend their MAF for 10min, so I can eliminate-find troublemaker in the car.
Andy
Any suggestions?
Andy
