Please help or advise
  • s2-1.5bar
    • Sep 2004
    • 193
    • Home: Lithuania Current: United Kingdom
    Hi Everybody,
    Seems eventualy I got rid of boost leaks. ( My opinion)
    Now I had a strange behavior of with fueling.Will try to explain:
    I got A/F meter fitted inside dashboard. When I drive normaly without sudden "pedal to the metal" the A/F ratio (lamda) shows (most times) about 1, which is normal.
    As soon I push it hard-the boost goes to 0.8bar, but A/F lights goes down and disapears-no readings. There is no boost cut out, just strange pulling power. I trying not to push hard in case A/F mixture goes lean.
    Could be faulty MAF, Temp sensor on top of IM, or fuel pump?
    Any suggestions?
    Of if anybody in NW area can lend their MAF for 10min, so I can eliminate-find troublemaker in the car.
    Andy
  • Chris M
    • Sep 2003
    • 1030
    Sounds like it could be MAF, try cleaning it along with the sensor on top of the IM. Also lambda could be faulty.
    HTH,
    Cheers,
    Chris
    Cheers,
    Chris
    Silver S2 Avant : Sold
    • s2-1.5bar
      • Sep 2004
      • 193
      Lambda probe-fitted new 4 months ago, MAF cleaned with IPA 2 weeks ago, IM temp sensor cleaned
      Any ideas how to check these items with basic circuit tester-multimeter?
      Andy
      • mcandmar
        • Apr 2004
        • 5118
        Does an S2 have a throttle position sensor? There a common failure on 7A engine's, when they go the car still drives but not very well.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • audiman
          • 4827
          Which way is it going?? Lean or rich?
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • audiman
            • 4827
            Any fault codes?
            Audi UR Quattro
            • s2-1.5bar
              • Sep 2004
              • 193
              Lean.
              • audiman
                • 4827
                Fuel pump failing??
                Audi UR Quattro
                • s2-1.5bar
                  • Sep 2004
                  • 193
                  Fuel pump failing??
                  I hope so-cheaper than new MAF
                  Thinking of fitting Sytec (Max pressure 8.0bar, pressure lock out 115psi, 180ltr/hour@3.0bar), price~ £150
                  • Ski
                    • 2591
                    Hi... Im in Old Trafford if you want to borrow my MAF. I would drive down to you but Im a bit broke since ive just emptied my pockets on lots of new toys / upgrades.
                    ABY Coupe
                    • s2-1.5bar
                      • Sep 2004
                      • 193
                      Hi,
                      Thanks for the offer. I planing to go to Manchester next w/end(sat) if you got spare half an hour that should do to me. Any time that suits you most.
                      Regards
                      Andy
                      • WabTheKing
                        • May 2004
                        • 2567
                        im not using mine at the mo as im rebuilding - my work is at the top of the m67 in hattersley save ski taking his apart
                        will
                        • s2-1.5bar
                          • Sep 2004
                          • 193
                          will
                          As in Yellow pages TV advert: " You Are Very Very Nice People"
                          Will pm you will tomorrow with regards of borrowing MAF.
                          • Ski
                            • 2591
                            Im not nice I was going to charge you by the hour
                            nah seriously if u still need it next weekend give me a shout
                            ABY Coupe
                            • s2-1.5bar
                              • Sep 2004
                              • 193
                              The Gremlin is located-faulty MAF,
                              Many thanks to Will, for letting me his MAF
