My boost gauge fitted
  • Jas11n
    • 5067
    I fitted my gauge a couple of months ago, but it's taken this long to get it right
    It originally came with a chrome bezel, which looked out of place in the car, and also had just a normal bulb for illumination which made the gauge light up white in the dark.
    This looked way out of place and was also quite distracting whilst driving.
    Solution was to spray the bezel mat black to match the 3 lower gauges.
    Next was to work out how to get it to light up red/orange instead of white. I tried using a normal red LED instead of the bulb but it was way to dim to be of any use. I also tried using a superbright red LED and again is was just a little too dim (like me ). Then I tried painting the original bulb with a thinned down red paint, but again it was way too dull.
    Finally spotted an extreme bright 4 x LED wedge type bulb (sidelight fitting) on fleabay. This works a treat The gauge now lights up red/orange in the dark.
    I'm happy now, yes I know this all sounds a bit ****, but I like things to be right
    The gauge is made by Sunpro (part of the snapon group in the US) and was bought off ebay, It reads in PSI but I ain't to bothered about that.
    (hard to see in the pics as it was taken in the dark, but the needle is red, matches the others quite well)
    As the saying goes, "Simple things please small minds"
    And lit up at night
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
  • gavs20v
    • Sep 2004
    • 3057
    Top job Jas, little touches like that make all the difference IMO
    nice one
    Gav
    S2 Cabriolet.........
    • Bibby
      • Aug 2004
      • 1043
      Silver bezel does look a bit out of place for sure. Just too lazy to change mine though.
      acidtrax
      • rotoryboy
        • May 2004
        • 3281
        Looks even better in the flesh, good work Jas. Attention to detail
        Mark
        Race Clio RS197
        S2 Coupe ABY (Green) - RIP
        S2 Coupe ABY (Blue) - Sold
        • Jas11n
          • 5067
          In the daylight
          • BRY
            • 3755
            Just done mine to match the Ice
            • Bibby
              • Aug 2004
              • 1043
              That looks funky!
              acidtrax
              • Baldy
                • 469
                • Home: Sikkim Current: British Antarctic Territory
                nice gauge
                put 1 i bought for mi old 10v UR in the other week but i think i need 1 that goes a touch higher
                clicky
                Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                0-60 4.9
                1/4mile 13.5
                • rotoryboy
                  • May 2004
                  • 3281
                  Weeeeeeeeee, lmao
                  Mark
                  Race Clio RS197
                  • Baldy
                    • 469
                    0-60 4.9
                    1/4mile 13.5
                    • gavs20v
                      • Sep 2004
                      • 3057
                      LMFAO, that cracked me up...weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                      • Baldy
                        • 469
                        if u cant go weeeeeeeeeeeeeeeeeeee on full boost when can do it?
                        0-60 4.9
                        1/4mile 13.5
                        • gavs20v
                          • Sep 2004
                          • 3057
                          fkcuk if you go weeee on full boost your cum face must be hilarious....ha ha ha ha ha ha!
                          • BRY
                            • 3755
                            Has someone else on here used the AC smoked gauge?
                            I wouldn't have got it if I didn't have the sony so that it matched, I would have got one like yours, do they come apart easy enough?
                              I never seen this thread before!
                              I've just bought 6xLED bulb for replacement on my Racetech boost gauge.
                              The one i ordered before didnt fit as the Racetech uses a BA9 bulb instead of standard twist one
