Darn car decided to break down last night and is now a non starter. I've done a few checks today and found there is no spark from the coil. Car is a 3B and was running ok when there was a pop from the exhaust on gearchange and then no power, coasted to a halt and then it stalled, since then it will not start. Ive checked for fault codes and there aren't any stored in the ECU. The dizzy rotates under cranking and all electrical leads are connected. Dizzy was new 1 year ago and has metal gear, dizzy cap and rotor arm look fine and the hall sensor on the dizzy is connected. I get no volts between the two terminals on the coil while cranking the engine, not dure if this imples there my be an issue with the coil, it's amplifier or the trigger signal from the flywheel or dizzy?? Does anyone know what I can check to narrow down my search for the fault? Suggestions greatly appreciated
Cheers Steve
Cheers Steve
I may try a temp fix and bond the pin (if I can find it) or something like it into the small recess that's left, it's got to be worth a try before pulling the engine out..
