3B that needs coil packs!
  • audiman
    • 4827
    I have now killed 2 std coils on my 3B running high boost. I know there are "high output" coils out there, but i was thinking of upgrading to the later type coil packs. Now i can get those coils cheap, but they need to be triggered.
    I dont want to be changing looms and ECU's as that is too costly.
    Fromwhat i can work out, the dizzy's hall sender gives the ECU 5 firing points for the coil. So using the original dizzy and hall sender, would it be possible for it to trigger an individual coil on a specific cylinder.
    The car is fine to drive as long as i dont drive using peak torque, which is a nightmare as you need to rev the engine hard Which i never do.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
  • porkkis
    • 1994
    No.
    Get the DF ECU and do the tricks to the harness.
    Tommy200rs has a howto about this @ 20v kruemmer yahoo group.
    • audiman
      • 4827
      DF ECU??? What is that?
      Audi UR Quattro
      • porkkis
        • 1994
        direct fire = coil per plug
        ecu
        • audiman
          • 4827
          His site inst that easy to follow, the conversion pages arent very clear to me at least. If i can help it, i dont want to be changing the ECU.
          Audi UR Quattro
          • quattronutter
            • Jan 2005
            • 690
            i have used high output coils on a couple of cars running higher boost after the originals gave in,cant remember the makes,think i got both from demon tweeks and never had any problems thereafter...
            • audiman
              • 4827
              It is tempting to buy an uprated coil. MSD make one IIRC.
              Audi UR Quattro
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Yeah man. Keep it 3B and hang on to that dizzy.
                SS
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  The ABY owners will tell you how unreliable these coil packs are.
                  SS
                    I'd say go with a Motorsport spec coil (like a suitable MSD item) - the complexity of upgrading to the DDI (Distributorless Direct Ignition) system is significant and costly but would pale into insigificance if you tried to grow your own 5-coil system.
                    Paul
                    • twoqu
                      • Sep 2003
                      • 3103
                      Hi!,
                      Wasn't Mihnea working on something like that?
                      Prices of suitable coils have dropped considerably, cheaper than leads.
                      I know aftermarket Ecus sometimes need the five window dizzy. The problem is going to be determining which coil fires when I guess.
                      • audiman
                        • 4827
                        After chatting with Mihnea about changing looms etc etc, its a major ball aching job. ECU isnt a problem. Loom is. Also to fit the thing is a nightmare, dash out etc etc.
                        It would almost be worth it so Mihnea can give me some sweet flames on gear changes tho :-D
                        Home-grown system is out of the window. It would be too complex with out much gain.
                        Audi UR Quattro
                        • audiman
                          • 4827
                          thats right robin. not an easy task for a spanner man
                          Audi UR Quattro
                          • audiman
                            • 4827
                            Well, i spent about 10 mins cleaning the electrodes on the inside of the dizzy cap today and all seems fine. Maybe the coil isnt at fault. The cap is only about 18 months old and so i, once again, thought it would be ok. After spending about 30 mins removing it and replacing it, and only 10 mins cleaning and WD-40ing it. I no longer have the cut out. Im gonna go and get some optimax and try again (as im running on cheapo 95 at the moment, dont tell me off mihnea, im skint), but first impressions were good. 1.8bar at 3600 with no cut out in 4th
                            Audi UR Quattro
                            • Billman
                              • 4129
                              what turbo do you have again? 1.8 at 3600 is good! What max boost and how much on the reds?
                              Go Holset or Go RS4
