Fiting side idicators ?
  • RS246
    • Dec 2005
    • 98
    • Country: Norway
    I have run in to som problems fiting my side indicators on the right side...
    There seem to be something in the way inside...
    Anyone have a solution for this problem?
    I think it has something to do with the air system to the fuel tank...
  • volcano rs
    • Jun 2005
    • 2265
    i had this same problem its the plastic tank for air con . you should have drilled higher up .
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      I'm not sure of the layout on the RS2, but it could be the carbon canister for the fuel vapours. I binned mine, as it was taking up valuable space, and it weighed nearly 1.5 kilos.
      SS
      • volcano rs
        • Jun 2005
        • 2265
        i dont think its the fuel vapour canister i'm sure its air con canister of some sort .
        • RS246
          • Dec 2005
          • 98
          • Country: Norway
          It was already drilled when i got the car.
          I was just going to change to white lamps...
          The old one on the right side was really tricky to remove... had to brake it
          Do you have any problems with gas smell after it is removed?
          Have a friend that drives witout it.... And the car smell like a gas station inside But then again his car i heavy tuned...
          I am not sure what to do here
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            No problems after removing the carbon canister. The tank now vents out the back of the car, just behind the rear wheel.
            SS
            • volcano rs
              • Jun 2005
              • 2265
              its a plastic tank i was told by the chap who drilled it in the wrong place that if you heat the plastic slowly and press it with your fingers to reshape it you should be able to fit the indicators .its the actual bulb holder that catches against the tank .
