Around the bottom of the windscreen there's two pieces of trim, kind if clipped together in the middle. The windscreen wiper spindles/axles/whatever-you-want-to-call-them stick through holes in this trim. In each half there are two screwdriver-rotated-clippy-things (it's too late in the day for technical type descriptions) which hold them in place. The passenger side (assuming Right Hand Drive) covers over the pollen filter (I believe) etc and sat under the other side is the fuse/relay box. There's a little rubber flap which appears to be part of the windscreen seal which just covers the top of these trim bits.
Question: Those two bits of trim, should they sealed down (underneath) with anything?
Cheers,
Ck.
Cheers,
Ck.
I suspect they are there for aerodynamics and to avoid leaves etc going where they shouldn't rather than being totally sealed, but I am prepared to be proven wrong....
