Fog lights
  • Jas11n
    • 5067
    Fog lights
    Just a quick query for you guys with 1995 or later S2's.
    Which foglights lenses are the correct ones?
    The versions with the vertical lines all the way across the lense, or the versions with the clear square just in front of the projector ?
    I think it's the second ones, but not 100% sure.
    I can't get my head around the chassis number listings in the FA and can't find any pics close enough to tell.
    Want to get these sorted as the ones I have now are very pitted and I don't want to buy the wrong ones
    Ana1 I know, but it's show season and want these along with new door/cill rubbers all the way round and new front bumper grilles.
    Thanks in advance.
    Jas
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    Mine have clear square where the projector is and the rest has vertical ribs on glass
      Mine is a later '93 ABY though. Door sill rubbers are different on 3B and ABY too
      • Jas11n
        • 5067
        Thanks Greg. I would go and look at my Bro's if I could pin him down for more than 2 mintues
        I know some might be thinking why not just order the same as you have, but then I've a secondhand bumper and lights etc after the incident last year.
        I have the wrong ones on now, so will get the new ones ordered up pronto
        • Briggsy
          • Jul 2005
          • 267
          hi jas, mine has the lines all the way across. and its 1995. hope this helps.
          1995 B4 Audi 80 S2 avant 267bhp and 326lbft *sold*
          2001 P38 Range Rover DHSE 159bhp and 255lbft
          1985 Type85 Audi 90 quattro 135bhp 140lbft
          • Jas11n
            • 5067
            Hmm, a head scratcher for sure this one.
            Finally managed to get hold of my bro and he has the clear window ones (95 Coupe)
            I also managed to find a close enough pic of mine before I bumped it, and it has the clear window ones too
            I think we need "Parts Daddy" to help here.
            May all sound a bit daft, but the ones on it now really are heavily pitted, so I may as well get the correct ones whilst I'm on
            • Briggsy
              • Jul 2005
              • 267
              mmmm...i think mine must have had a bumper relplaced at some point!!
              • Briggsy
                • Jul 2005
                • 267
                im just unsure now!
                cos i just went outside and looked, and i could see lines all the way across my fogs but in this pic it looks as if there is a clear window over the projector!
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  Hi Jas,
                  Mine was built in Oct/Nov '94, sold '95 and also has the vertical lines all the way across, as do the indicators, so they match.
                  .....except that the fogs are glass...why did they use glass for the fogs and plastic for the indicators? They don't quite look the same side by side and that bugs me
                  Cheers n
                  Si
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                  • Jas11n
                    • 5067
                    Think I'm getting to the bottom of this now.
                    (Click on each pic to see the full size one)
                    Below is what I had before I broke them (shhh, forget it will ya Jas !)
                    And now below are what I have at the minute, (It is the same car BTW, really looks blue at times )
                    Also found this thread here that confirms the type with the clear window are the later ones, which tallies with what I used to have.
                    I've also noticed with the ones I have in now, that they sit back slightly from the indicator, which they didn't do before.
                    • Jas11n
                      • 5067
                      @ Briggsy, those are the clear window type.
                      @ Si, now I'm stumped again
                      Feckin fogs, don't even use the damn things either
                      • Briggsy
                        • Jul 2005
                        • 267
                        yeah i see, but the ones you have in now are from audi 90's.
                        • Briggsy
                          • Jul 2005
                          • 267
                          here you go.
                          • Jas11n
                            • 5067
                            here you go.
                            Yep, seems I have the earlier ones. Just spoken to a mate with a 3B and those above are in his too.
                            So, clear window ones will be getting bought next week along with new bottom door/ rear quarter rubbers and two new bumper grilles (already have a new nearside one).
                            Thanks for the help chaps
                            • s2_southwest
                              • Oct 2004
                              • 823
                              ive got the ones that you have fitted at the mo jas, mines an early 91 3b so yes looks like they are the older type....i like the look of the newer type though
                              Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
