Light bulb
  • Ski
    • 2591
    Light bulb
    erm.. Dont want to sound like a newbie.. but im having difficulties changing the drivers side side-light.
    when i had my 80 2.6 Q was np.. but this s2 got some b33f under the bonnet and my arm wont reach.. do i have to start taking bits off my front end?
    ABY Coupe
  • Doug_RS2
    • 3847
    It literally only takes 5 minutes to pull the headlight out - 2 screws on top, 1 screw for the trim under the headlight and 2 more screws under the headlight - dead easy.
    • Lee
      • 1512
      Yep, quickest way to change the bulbs. I don't even understand why I attempted it with the headlamps in situ now (like the first 2 times I changed the bulbs!!).Dead easy. I found pulling the bottom end of the unit out (push top in first) on mine to be the easiest way..not sure if that is due to the RS2 bumper I have or whether that's how everyone else does it.
      Lee
      Designun Limited....
      • Ski
        • 2591
        oki got it.. do i goto mess around with aligning the light up again or will it fit back perfect?
        ABY Coupe
        • Lee
          • 1512
          It will fit back fine. Adjustment is done in the headlight itself.
          • Ski
            • 2591
            while im on the subject, anyways to make my lights white.. yellow dont cut it (the glass).
            ABY Coupe
            • Lee
              • 1512
              Get yourself a HID kit from www.vagparts.com MartynF or Audi Parts Guru can help you out. So white, their almost blue if you know what I mean. I have seen them installed and they are well impressive. Told they were brighter than those fitted to the new Range Rovers.
