Avant tailgate trim
  • alg
    • Apr 2004
    • 1160
    Avant tailgate trim
    I need to replace a brake bulb. How do I remove the interior trim? There are two screws on the latch trim. Do I remove those and unclip the trim ?
    Alastair
    RS2
  • GT500
    • Jun 2006
    • 2181
    Are you on about a center brake light? if so yes remove the two screws in the handle then peel the panel back. the fasteners let go quite easily, be sure to line them up on refit.
    my lhd rs2 only has the usual two brake lights.. accessed through the battery and washer bottle cover...
    Rob
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      GT500 is correct,brake lights on the RS2 are located on the outside lights,not the inside,so there is no need to open the interior trim.Bulbs located there are the rear fog lights and the reverse gear lights.
      However removing the trim is as described quite easy.Unscrew the 2 bolts and then gently with a screwdriver unhook each clip from it's securing hole.
      • alg
        • Apr 2004
        • 1160
        Yes you are correct and I am going mad Sorry
        Alastair
        RS2
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          i think im superior in madness,i unhooked the trim a few months ago to fit foam silencers to reduce bump noises coming from there.I did a really good job might i add!I get no squeeks from my RS2!!! im proud!
