Few places to check in a long term relationship with B4 Avant (rust)
  • Vauhtiveikko
    • Jun 2010
    • 250
    Getting there piece by piece...
    This gallery has 3 photos.
    S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
    • Vauhtiveikko
      • Jun 2010
      • 250
      Finally got the beast on its wheels. 7 months since last drive...
      This gallery has 2 photos.
        • Dec 2017
        • 5991
        Well done. I'm not even half done!
        • rxl
          • 1913
          that was fast!!well done!! moast of the cars here on forum end up on jacks for many years
          • Vauhtiveikko
            • Jun 2010
            • 250
            It felt like a lifetime, because all I wanted to do was change the fuel filter and winter tyres at the first place...
            Happy still that car is ready for summer trips and burnouts. Next MOT time.
            • Lago Blue
              • Jul 2009
              • 843
              Favourite B4 rust spots: After all the under-body fuel lines under those rubber/stainless factory clamps, which are pretty obvious, perhaps less so these Audi 90 B4 Rr Susp Brackets new and old rusty backsides.png
              rear suspension brackets can sometimes appear OK but really be done on the back-sides and worse (this one is really rather mild, see at least one horror story at the link it's from below)...
              Pulled these off a few weeks ago to fit H&R lowering springs. Then icked up some PSS9s and refurbed turrets and fitted them earlier today.   The
              What I did:
              The design intent in having the rear skin on these may be to ensure the four bolts always share the loads well and equally, but because of the close proximity of that large inner bracket surface when installed next to the inner fender shell proper and lack of a weather-seal, it's a great water/grunge trap. Luckily, mine where in really good shape, I re-sprayed them with additional paint (even new ones aren't painted really well), and afterwards liberally with wax/oil and then made 4 thin hard plastic spacers to increase the installed clearance; to encourage drying behind the brackets. The slight changes are accommodated with a re-alignment. That was a decade ago and has worked well.
              • Rudpavv
                • May 2017
                • 15
                • Country: Poland
                #22
                Check all the drains. One of mines were clogged and I had to weld in a patch
                  • Dec 2017
                  • 5991
                  And here. Same both sides!
                  • Rudpavv
                    • May 2017
                    • 15
                    • Country: Poland
                    #24
                    I had the same exact rust hole in my a80. I just widened it with a dremel to get rid of all the rust. Painted it with a epoxy primer and stuck a rubber plug in there.
                    • Vauhtiveikko
                      • Jun 2010
                      • 250
                      Same as mine - I did a plug welds for those and left the holes out. The exhaust back muffler heat shield I made from aluminium mesh because I found no better replacement.
