Metal sunroof rot
    Here we go, hope this helps in some way:
    • Ebra
      • Oct 2019
      • 7
      Hi all - also looking for a new sunroof due to rot. Preferably glass but metal would do. I couldn’t find the metal one on Audi Tradition...anyone have the link? Thanks!
      • Ebra
        • Oct 2019
        • 7
        Apologies, found it!
        • arranstone
          • May 2011
          • 447
          Can you provide the link please, I'm looking for a sunroof panel too.
          • Ebra
            • Oct 2019
            • 7
            Think this is it:
            https://audi.7zap.com/en/rdw/audi+co.../877-877000/#1
              • Dec 2017
              • 5986
              There is a B4 80 sunroof for sale on ebay tonight.
              • arranstone
                • May 2011
                • 447
                can you post the link please.
                  • Dec 2017
                  • 5986
                  https://www.ebay.co.uk/itm/AUDI-80-9...edirect=mobile
                    • 4754
                    That looks very clean and a good price.
                    • Ebra
                      • Oct 2019
                      • 7
                      Before I give up on my glass sunroof and look into the full switch to metal, please anyone let me know if you have a glass panel (with metal backing) in decent shape available to purchase! Thanks
                      • Waje
                        • Nov 2016
                        • 95
                        • Country: Spain
                        #41
                        Good afternoon, a while ago, driving on the highway at high speed, my glass roof said goodbye, unfortunately the frame, which was rotten but apparently quite decent, has bent. I am considering the possibility, given the urgency now, to put a metallic one temporarily, someone could tell me if I could put it? to be able to cover the gap. Can someone confirm if I can put the metal in the place of the glass? Thank you.
                        REGARDS
                        • Ebra
                          • Oct 2019
                          • 7
                          Hi - you may want to consider a permanent replacement with a metal sunroof. From my experience the glass roofs are no longer available new from Audi and if you find a used one it is more than likely suffering from some rot. The metal roofs run on a different mechanism so you won’t be able to fix a metal panel onto your existing mechanism. I did the full switch last year so let me know if you need any info.
                          • rynaqui
                            • Mar 2012
                            • 2752
                            • Country: Malta
                            #43
                            Mine is completely shut and the mechanism won't work anymore. Need a full transplant to metal as well at some point so I feel your pain.
                            1996 S2 ABY Silver
                            • MOTORHOOLIGAN
                              • May 2010
                              • 119
                              • Country: Spain
                              #44
                              REGARDS
                              Im not sure its the correct sunroof to your car
                              AUDI 80 90 B4 COUPE TWO 2 POSITION SUNROOF MECHANISM METAL PANEL 895877371 | eBay
                              https://www.ebay.co.uk/itm/AUDI-80-9...x8AAOSwp1Rf9v2 I
                              AUDI 80 90 B4 SALOON TWO 2 POSITION SUNROOF METAL PANEL LY9Z GOLF JETTA | eBay
                              https://www.ebay.co.uk/itm/AUDI-80-9...8EAAOSwhXxeSUv j
                              • Waje
                                • Nov 2016
                                • 95
                                • Country: Spain
                                #45
                                I keep investigating and I have discovered that they are not the same for Avant / sedan as for coupe, among the B4 coupes the glass and steel top are compatible, but among the rest they are not, at least that is what I see in ETKA, despite any help is appreciated.
                                REGARDS
