Windscreen removal and fitting
  • Rikki Kitto
    • Feb 2010
    • 6276
    Finally got my hands on a heated screen now the nightmare of finding a capable fitter and finding any other parts I might need Anyone got a list and recomendations Screen is in Tamworth so probably best to drive up there and get it done
  • Fat Audi 80
    • 10547
    Contact Russ at Ultimate Windscreens, He did mine 18 months ago and is a craftsman. He even went to the trouble of sealing up the slight area of rust under the windscreen... (You may have to travel to him though)
    Welcome to Ultimate Windscreens, established 2011. Ultimate Windscreens are an independent Windscreen Repair & Replacement company that specialise in windscreen replacement of cracked and damaged windscreens, broken door glasses and heated rear screens in a variety of vehicles from cars to commercials. Ultimate Windscreens has acquired various qualifications over the years and currently registered with the
    Good luck
    The Perfectionist
    • Fat Audi 80
      • 10547
      Show & Specialist Have you got something a bit special, or building a show car? Ultimate Windscreens have worked on some amazing builds over the past few years, from souped up Audi's, to classic BMW's. If you'd like more information about what we can offer you, or to request a quote, please use our contact
      The Perfectionist
      • AndyP
        • 6049
        Based in Telford?
        How long do you have to leave it before driving home?
        • Fat Audi 80
          • 10547
          I drove home after an hour or two. It takes over an hour to put the car back together properly after the windscreen has been fitted...
          The Perfectionist
          • Rikki Kitto
            • Feb 2010
            • 6276
            Do I need any new seals or fittings
            • SteveH
              • 4460
              If you can source them, get new top and bottom trims for the screen. You will likely have some corrosion under the screen at the roof edge. Definitely get this sorted while the screen is out.
              91 Modded 3B
              14 A6 Avant Black Edition
              • Rikki Kitto
                • Feb 2010
                • 6276
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  Any idea if these are on Audi Tradition I've looked but no idea how to find on their site
                  • SteveH
                    • 4460
                    These folk used to stock them. They're not showing on their website, but they may be able to get hold of them for you. Worth a try...
                    Buy Esprit, Sensor Tack Windscreen Repair Equipment online. Buy Dinitrol rust prevention and rust treatment from Rejel. Free delivery for orders over £70. Rust proofing kits available for protecting vehicles of all sizes.
                    91 Modded 3B
                    • steve briance
                      • Aug 2014
                      • 1455
                      The mobile fitter I used last year had seals but they were on a roll. Virtually the only difference between his generic roll of seal and the outgoing audi one was that his had no rigid/shaped core. Once fitted and screen glued in, it is hard to tell otherwise and I cant see a need for it to be rigid as it is stuck to the shell!
                      I used Midlands autoglass and he was alright but he only had to supply and fit the glass, the car was being resprayed so didn't have to do any dismantling or rebuilding so I can't comment on that aspect.
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        Cheers peeps getting resprayed this year too so should be ok if finish isn't perfect body shop can help out
                        • steve briance
                          • Aug 2014
                          • 1455
                          Do you need to fit it now or could it wait till respray?
                          Bodyshop won't want to take screen out for fear of breaking it and therefore won't be able to deal with any corrosion revealed when window is removed assuming the window fitter doesnt sort it.
                          The guy who did mine was fairly local to body shop and was more than happy to drop by one day to remove the screen and then come back when the paint was done to put new one in, I just coveres his extra fuel which I thought is fair enough.
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Good point No rush to get it in and the guys who are prepping the car are flexible so will probably wait and tie it all in together
                            • AndyP
                              • 6049
                              Tradition have all 4 seals as I've just bought them in the last group buy. Make sure you're sitting down when you check the price!!
