Anyone know what model the Aero wiper blade kit for an Avant uses?
Obviously complete kit was bought from VAG parts prior to me buying the car but now i just need to change the blades themselves.
Guessing Lupo or similar??
Any ideas.
Cheers Pete.
'If you ain't broke it you ain't trying hard enough'
Oh sh*t i broke it
94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
Not sure but VAG parts list the coupe kit and the avant seperate and they are a different price so me thinks they might be different.
Ragusa Coupe gone!
while you are at it Jas, could you post the p/n for the arms (coupe)too if you have em handy
Crawf
Ragusa Coupe gone!
Crawf
Yup, but it gets a little confusing, so here goes.
The part numbers I have on the receipt are "6X2 998 405" but if you were to order this, you'd get the arm "and" the blade.
The blade on it's own is "6X1 955 409A" (RHD Lupo left hand arm) You need two of these.
The early VAGParts kit came with 2 x lupo arms and blades and one longer passat blade. Hence I have one short blade as a spare. I think the kit now comes with exactly what you need, nothing spare, as per what my bro got when he oredered his set.
As for the difference between the Coupe and Avant, I didn't realise this.
I apologise, I'll get me coat and exit stage left <<<<<
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
Go away Jas,sit down and reflect on what youve done.
Although there may be a way out if you've bought some Coupe ones.
Sell the Avant and buy a Coupe to put them on. Problem solved and you'll have a cooler car to boot
Jas..
[I can hear the running footsteps from here]
