Exterior window rubbers
  • bilko0795
    • Feb 2011
    • 1883
    Can you still get these if so any one have the part numbers please.
    thanks
  • curlyks2
    • 1069
    Can you be more specific please - which window(s)?
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
    • bilko0795
      • Feb 2011
      • 1883
      Rear quarter glass
      • curlyks2
        • 1069
        I think that is part(s) 22 on this diagram, listed as "seal for side window" with part numbers 895845321C (left) and 895845322C (right), both showing as "Cancelled since 01.03.2014". However, cached search suggests that Audi Tradition may still supply (when it comes back from holiday), and eBay.de seems to show both.
        • bilko0795
          • Feb 2011
          • 1883
          Thanks for that
          • bilko0795
            • Feb 2011
            • 1883
            Right been checking again it’s not the window rubber it’s the long rubber that seems to go over the top of the window rubber from front to back it’s clipped under the trim on the rear C piller don’t know if it’s only on S2 coupe’s or all.
            • steve briance
              • Aug 2014
              • 1455
              That isn't really a rubber. It is an aluminium extrusion which has a rubber lip bonded to it. The extrusion is what holds the door seal in place. To get at it you will need to remove all the glass, seals and b pillar trim and drill our a load of rivets.
              It's not on the diagram above so have a Google search for a different one.
              I'd be amazed of tradition remake theses.
              Second hand might be the only way forward.
              • bilko0795
                • Feb 2011
                • 1883
                Thanks Steve the end of mine has broken off will probably have to use tiger seal to pop it back on but will check the internet.
                • steve briance
                  • Aug 2014
                  • 1455
                  It's a pain in the **** to get to. So much dismantling needed and then when it comes off, it's really thin and hardly anything to it! ​​​​​​
                  • jeffstoo
                    • Apr 2011
                    • 98
                    Funnily enough I have just been looking for the exact same trim. Tradition do have them for something like 227 euros. I think I might wait until a used one comes up. Part No for RH side 895853704C.
                    • bilko0795
                      • Feb 2011
                      • 1883
                      Just checked €253.27 that’s expensive second hand will be just as brittle I will have to Rob a bank
                      • curlyks2
                        • 1069
                        Part 21 in the attached picture, 895853704C as jeffstoo says for the right hand side, 895853703C for the left. Not exclusive to S2 according to the family album - fitted to (Europe) 1989 - 1996 Coupe and Coupe quattro models.
                        ETA: there was also a satin black version which was NLA'd in 2013/2014. Part numbers are the same with 01C appended to end.
                        This gallery has 1 photos.
                        • bilko0795
                          • Feb 2011
                          • 1883
                          Thanks for that
