Why can't I use two left S2 fogs in bumper?
  • rs2coupe
    • Oct 2004
    • 1782
    • Home: Trinidad and Tobago Current: United States
    Just curious know if I were to use 2 left side fog lamps on both corners of the S2 bumper will it make a difference in fitting and wiring up?
    They look from pictures like they are interchangeable, but I have not really given much attention to one when I had it in my hand.
    Cheers mis amigos,
    _Anton
  • WabTheKing
    • May 2004
    • 2567
    they are different, and wires will be too short
    • rs2coupe
      • Oct 2004
      • 1782
      Ok let's say I lengthen the wires I would still have a problem with them fitting properly aligned?
      Iam hoping I can get away with it but if the answer is no then dead end on a cheap fix for me.
      Cheers mis amigos,
      _Anton
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        I might be being dumb here (in fact almost certainly) but I assume you are suggesting simply rotating the left one over and mounting it on the right hand side?
        Since fog lights are angled downwards (which is why they are pointless and every chav who drives around with them on should be shot), won't that mean that if you mount the left one upside down, it will point up?
        If that is the case, Plod would pull you if you ever switched them on.
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • rs2coupe
          • Oct 2004
          • 1782
          Cheers n
          Si
          Yup you were reading my mind.... well I've got my answer and soo thanks for the clarity
          Cheers mis amigos,
          _Anton
          • Fat Audi 80
            • 10547
            Bloody hell, I was getting confused there too!
            The Perfectionist
