There are two 'u' shaped brackets under the front of my s2 avant, under the front of the front footwells, which I assume are mounting points for lifting the car on a ramp.
Does anyone else have the problem of these grounding out over speed bumps, the sort of yellow / black plastic variety mostly.
If I go at anything faster than a crawl over these, the car crashes down on these brackets with quite a force.
I don't know if my car is lowered at all, which might aggrevate the problem.
What would the standard ride height be for the car on stock 16" avus rims??
