Just took my door card off 2 find what was up with my window and found the cable was frayed gunna order a cable set tomorrow just wondered if i have 2 take the whole mechanism out or just the motor and fit the cable with it in place?
Yep, actually one bolt and one nut below that at the top right hand corner (drivers side). Make sure the window is wound down before removing it to make life a little easier for you.
