Hi guys, put this in here as I believe the exterior is the problem.....
Right I have 4 leaks in teh front of the car leading to pooling in both footwells.....
Two (one from eash side are coming from teh door seals (running down the inside then over the lip at the bottom, Cure anyone???? Tried to silica seal up part of it and it has reduced the problem from this area but not by much.
The other two are ?????
I think that they are coming from the join at the back of the bonnet. If you look at the top of the wing with the door and bonnet open you can see three interior panels joined together. There appears to be a little hole there which I have silica sealed but no joy still leaking.....
Any more thoughts. The water seems to be running down wires on both sides (drivers and passengers ) and coming from way up high so quite hard to spot from underneath....
Thoughts please ladies and gents as this needs to be done before the carpet gets back in there for obvious reasons......
Az
P.S. Laminate floor underlay makes a great replacement for the sound proofing especially if you use the wjite waterproof foam stuff!!!!
Az
Az
Az
