If your just pulling it off pushing a new one on should not be too hard providing you undo everything on it, i'll let you know in about a weeks time as might be doing one
nice - a few pics of the relevant fixings etc would be awesomely helpful if you get the chance mate
I've only got a haynes manual for the 80/90/coupe and dash removal is funnily enough not listed
also, perhaps a kindly mod can move this to interior section? - its been a long day!!
i've just bought some S2 door cards, but i can't work out if tehy are the dark grey plastic or black.... I'll want a dash to match but might well be interested in yours Az - i'll let you know when these cards turn up
I just couldn't work out where it was secured inside the car
Held on at 8 points.
2 each side under the circular bits as you open the door
2 each under the carpet attatched to a bracket which is in turn attatched to the tunnel....
Have to undo all the center console, switch/heater controls everything in the center. There is also a bolt/nut attatched to what I call the moose horn (plastic air flowing thingy that supplies the side vents - looks like a moose when put on head and drunk!!!)
then the thing lifts out (steerign wheel etc removed of course)
Dark Grey Avant
RS2 FARB
Alloy Subframe Bushes
