rear carbon panel + carbon roof ?
  • Albert
    • 1500
    • Country: Poland
    I would like to modyfy audi S2 rear pannel and use light carbon to loose weight. I have seen modifications done to couple of S2.
    Also I have seen one modification of the roof.
    Is there a place I could buy the rear carbon panel ? AFIAK the roof is coustom made for the car.
    AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
  • Acidburn
    • 13459
    From what i've seen that is jonus's car (not sure i've spelt his name right) so you could try contact him. think he might be a member also check out a thread I did for wide arches as iirc that had a link to his website.
    • dest
      • 4287
      It would be very expensive, and not really make that much difference TBH.
      A friend of mine spent an obscene amount of money getting a custom bonnet and boot lid panel made from carbon, it didnt really make that much of a noticable difference, and that was on a car that was already stripped out for the track.
      • NEO
        • Oct 2003
        • 326
        Some for sale in sweden. Old add though... Dunno if they still are available:
        Sveriges största cirkulära marknad. Köp & sälj begagnat & second hand, enkelt & hållbart. Mode, Inredning, Elektronik, Motor, Samlarobjekt & mer | Tradera.
        /NEO - I have a sexual thing for big brakes.
        www.irry.com | Irry got a face lift!
        #nordicaudi @ irc.nordicaudi.com
        • Albert
          • 1500
          • Country: Poland
          thanks a lot
          • 20vK
            • Nov 2007
            • 29
            Think I save 12kgs on a mk2 golf bonnet and around the same on a carbon roof. That's already 25kg's, so it does add up quickly.
            I know with mk2 golfs, the roof is spotwelded most the way along. You can just take a fibreglass mold off it (obviously before you drill the spot welds), and then you could take the mold to someone with carbon laying skills and facilities, for the carbon componant to be made up for you.
            You bond on the roof to the car with the same stuff they stick windturbine blades together with. Expensive, but strong!
            HTH
            Rich
            • shortsport
              • Dec 2006
              • 186
              I'm thinking of making my roof with carbon/kevlar(to do away with the sunroof)might be a bit tricky but should be able to do a reasonable job of it.With the front wing in carbon/kevlar it weighs about 2lbs(0.9kg)
              • Jeffer
                • 2057
                HTH
                Rich
                Rich, what would this be called exactly?
                Thanx
                RS2 Black - stock 315 HP
                RS2 RS blau - stock 315 HP
                Sport Quattro - 1005 HP
                High Octane website
                • 20vK
                  • Nov 2007
                  • 29
                  I'll have a look when I get back to my warehouse - I've got a drum of the stuff (cost around £500, from memory), but you only need a tiny amount, so don't let that scare you off!
                  It's a 2-part resin that goes pinkish when you mix it. It's got a fairly dense consistancy to it, so you can apply it to the surfaces, without it running. (think of a chewet sweet on a very warm day and it looks a bit like that!) Clamp your 2 surfaces, and 24hrs later - voila!
                  I've a friend who's got pretty far with building his carbon car and it's amazing how rigid all the "floppy" carbon panels become after they're bonded together.
                  Shortsport - I'm interested to know why you choose to use kevlar in the roof laminate, as opposed to a 100% carbon? You intending on skidding on your roof, any time soon!
                  Rich
                  • shortsport
                    • Dec 2006
                    • 186
                    Carbon/kevlar is cheaper than carbon fibre and to get the best of carbon fibre you need pre preg which is expensive,you need to keep it in a freezer and need an autoclave to cure it,so I went for carbon/kevlar because i,m using a lay up resin and the weight difference is in how much resin you use + Audi uesd kevlar on the short sport panels and roof
                    • 20vK
                      • Nov 2007
                      • 29
                      Have you looked at resin infusion?
                      Close to the perfect ratio of resin / carbon, as in pre-preg, without any of the hassle of a freezer / cost of an autoclave.
                      It's still not as good as prepreg, but the strength to weight increase over vac-bagged layup is substantial and very close to pre-preg.
                      • PhilS2R
                        • Sep 2003
                        • 116
                        • Country: France
                        You have this adress in France for part in Carbon/Kvelar...
                        God forgives...... Me not....
                        and
                        If you disturbs the dog...
                        It will puff out you the hand !!!
                        Pitbull Proverb
