RS2 door mirrors
  • Mark Halligan
    • 2001
    RS2 door mirrors
    Does anyone know how to remove the mirror glass from the RS2 door mirrors. I've been poking around in the little hole thats on the underside with a screwdriver but I cant find anything that will release the glass from the mirror assembly .
    Cheers,
    Mark.
    Mark - Modded
  • jubjub
    • Nov 2003
    • 1239
    Thats funny, as i have got to take my NS side mirror off as the motor has stopped movement to the left and right... I think if memory serves in them little holes underneath there is a cam with teeth. You have to work it one way and it just releases..... IIRC you may have to push the top part of the mirror in to the housing so the bottom part of the mirror sticks out slightly. If you look in the holes you should see the little teeth.It is a fiddly job.
    • Mark Halligan
      • 2001
      Thanks Dean.
      Mark.
      Mark - Modded
      • Graham
        • 1622
        I had to replace a bust one on my old coupe and they are a **** to get off, there is a set of about 6-8 little clips which clip onto the bezel which the motors operate, gawd knows how you would get them off without breaking them and at 45 quid for a glass it was an expensive f*ck up when i didnt have all the clips in place and my 3 day old mirror went whoosh at 70 on the motorway . In the end i got one of the blokes at Audi to clip it in place as the pressure you put on to expand all of the clips is scary i feared snapping the mirror.
        Graham
        P.s. what does IIRC mean?
        • APNess
          • 479
          If I recall correctly IIRC means... oh. Well, I think you know now :S
          PJ
          'The Bacofoil Express'...
          No more.
          Leon TDI 150 run in now.
          Very slow.
          Needs a chip.
          • Doug_RS2
            • 3847
            The RS2 ones are different to normal mirrors.
            As jubjub says there is a circular flange on the back of the mirror that needs to be rotated one way to unlock the mirror. You should be able to see that at the bottom of the mirror - as a small screwdriver can move it back and forward. It should pull out after that has been unlocked.
            • Doug_RS2
              • 3847
              roughly where the arrow is:
              • Mark Halligan
                • 2001
                Yep amazing how easy it is once you've broke one getting it out, its all quite clear now .
                Mark.
                Mark - Modded
                • S2 Ant
                  • 3682
                  Was that an expensive breakage tho? or not too bad
                  Ant
                  2011 Kawasaki Z1000
                  • jubjub
                    • Nov 2003
                    • 1239
                    what happened?
                    • Mark Halligan
                      • 2001
                      Dean,
                      dunno mate, pushed, pulled or twisted too hard..........I think I ran out of patience with it, silly really .
                      Thanks for reminding me Ant, yes about £40 .
                      Mark.
                      Mark - Modded
                      • jubjub
                        • Nov 2003
                        • 1239
                        .....I know its just going to be an accident waiting to happen when i look at mine......
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          If you spray the circle shaped clip at the back of the mirror with silicon spray or even furniture polish it will clip on more easily and even may come off more easily as well
                          Worth a try and doesn't cost anything.
                          HTH
                          David
                          • Mark Halligan
                            • 2001
                            Finally got around to fitting the RS2 mirrors today, not to sure that they are much of an 'upgrade' as the view that they give is nowhere near as good as the standard ones.
                            Mind you though, they do look nice .
                            Mark.
                            Mark - Modded
                            • Dr H
                              • 1175
                              Lookin' good
                              I see you've painted the headlights as well. I'm thinking of doing mine but it's starting to get too common
                              Ex 1994 Avant - now driving a Lotus 340r
