Removing weight
  • VladaS2
    • Aug 2006
    • 185
    • Country: Yugoslavia
    Removing weight
    On a drag strip I remove seats and the spare tire. I already had A/C removed before. With this setup the car is about 1360kg.
    What else is relatively easy to remove/replace?
    My Online Blog
  • Flat on my back
    • Jan 2007
    • 2449
    Run with the minimun of fuel you can get away with...or install a seperate small tank for race days.
    Carlos.
    • dest
      • 4287
      The passenger seat!
      Only one bolt to remove it, if you have never removed one before you will be surprised at how heavy they are
      Edit: Ignore me, I didnt read your post fully
      • VladaS2
        • Aug 2006
        • 185
        So we have:
        - Seats (around 25kg all together)
        - Spare tire (around 20kg)
        - Air Condition (40kg)
        - Minimum fuel
        What else can be pulled off form standard car.
        My Online Blog
        • Flat on my back
          • Jan 2007
          • 2449
          Smaller battery,
          Disconnect alternator belt.
          Get the wife to drive it...
          Carlos.
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            I'm running a 18amp, 5.5kg battery. Saves more than 10kg compared to a stock sized battery.
            Started right up after sitting in -20 degree temperatures for close to a week. Was utterly amazed by that
            Have also replaced the aluminum spare tire well cover with one made from high density styrofoam. Saved approx. 3kg
            1994 80E Avant
            1986 2L Golf 2 on Alcohol
            • Keeper of The Kitten
              • Dec 2003
              • 2317
              Are you using stock wheels or larger aftermarket wheels?
              A set of smaller wheels or just the lightest type you can get will always provide benefits - especially on the dragstrip.
              If you've got bigger brakes it might not be possible (bigger brake discs would also be a bigger weight penalty)
              Martin Cutting
              • K Simmonds
                • Dec 2007
                • 7627
                On top of the suggestions above you could lose the middle box on the exhaust system or ideally replace the the whole lot as the standard system weighs a lot. Aux rad, rear wiper and washer bottle, sound insulation, headlight washer's and bottle, carbon canister and stereo. That just of the top off my head I'm sure there is a fair bit more if you really put your mind to it.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                • Acidburn
                  • 13459
                  Martyn f did quite a bit of investigation about the weight of the wheels, i've been trying to find the thread with his info think some bbs wheels was lightest?
                  Dash weighs a bit and you can remove the glovebox/under steering tray
                  • EspenW
                    • Apr 2007
                    • 1534
                    • Country: Norway
                    Saving rotating weight will have the greatest impact. The further from the center the weight is removed, the better. Saving 1kg from the outer diameter equals close to 2kg of static weight. Increases with distance from center to the second power. Save 1kg at r=1/2 equals 1.25kg of rotating weight.
                    In other words, lightweight tires are more important than light rims.
                    My RS2 came with 18" Turbo Cup (by Mille Miglia) rims for summer use. Sold them and replaced with stock 17" Cups with Conti Sport Contact 3's. The weight saving equaled close to 30kg of static weight.
                    1994 80E Avant
                      • Dec 2003
                      • 2317
                      Agree with EspenW completely, rotating mass, inertia - which is why it's important for the drags (change from static car to moving), but it's important for everything to do with a moving vehicle - changing direction or speed, left or right, faster or slower.
                      Martin Cutting
                      • Rusty
                        • 18953
                        Wheels wise, I found a site that had most wheels and weights, here. The superleggeras that I have are amonst the lightest. You can notice the increase in acceleration.
                        Reduce the rotating mass of everything and get the engine balanced so it revs better. Get a relay and wire it up to disconnect the alternator on full load so that there is minimal drag on the pulley, remove the rear carpet, door cards, trim, seatbelts, wiper and washer bottle, drain the front washer bottle... etc. etc.
                        • quattronutter
                          • Jan 2005
                          • 690
                          join weight watchers too
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            A lighter driver will improve 1/4 mile times BTDT.
                            SS
                            • T2Andy
                              • 1903
