Battery Cut Out
  • Michel
    • 150
    Battery Cut Out
    As the car will soon no long be used every sinlge day I'm wondering about installing a battery cut out on an M plate ABY Avant.
    Its got a period Clifford Alarm immobiliser on it and I'm qwondering how they respond to having no power for a while.
    I use a battery cut out on another car without problems but have never tried it on one with an alarm etc.
    Any ideas?
  • Stick Insect
    • Dec 2003
    • 2338
    Michel,
    If the car is in a garage I would just put a battery trickle charger on the car. There is a battery cut available which has a small bypass fuse. This allows the clock alarm etc to keep working ok and protects against a short circuit / fire scenario.
    If the car is started it will need to have the switch turned on.
    Batteries need to be excercised, they don't like sitting.
    David
    • Michel
      • 150
      Unfortuneately its not in the garage.....on the street.
      The others live there all with trickle chargers.
      But no room for this one.
      I can get ot a garge but it doesn't have mains power...hence the query.
      Cheers.
      • SteveH
        • 4460
        I've seen solar cell trickle chargers. You just stick them on the parcel shelf and let them do their job.
        Quick Google search and Bobs yer uncle
        http://www.siliconsolar.com/car_battery_chargers.htm
        Only $25 too!
        HTH
        91 Modded 3B
        14 A6 Avant Black Edition
          you can get those solar charger things from maplins etc too.
          • Stick Insect
            • Dec 2003
            • 2338
            Greg and Steve,
            he lives in London, The sun doesn't shine there, It's only sunny in Manchester!
            If he had a coupe he could have a waterpowered unit working off the leaks in the boot!
            Slipper warmer could be wired in as well!
            David
            • Michel
              • 150
              Too right down F##k##g sun down here.
              I'd get it charged up when I come up M'chester to see the outlaws and my brother tho....
              Water power...now where's that leaking washer pipe gone....
              Cheers Guys.
