Bonnet question
  • VFR
    • 7
    Bonnet question
    I have a '91 2.3 coupe Q. I have found a bonnet from the S2
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=10372
    which is the one with the extended front (it includes the grille were mine is the ''flat'' one). Does anybody knows if it is a straight replacement ar if it needs modification in order to fit??
    Many thanx
    d.
  • desmo888
    • Oct 2003
    • 390
    need to change the front core support too.
    These items can be had off a standard 93-95 90 series car.
    Dave K.
    USA
    1991 e//S2 (home built S2 - the only way to get one in USA!)
    2001 S4
    • VFR
      • 7
      you mean the support for small radiator, no?
      also good luck with your project ( converting it to S2...) ... I hope sometime, I do the same (if I find all the parts... )
      • Stick Insect
        • Dec 2003
        • 2338
        VFR, Go to a scrapyeard near you and get an audi 80/90 bonnet. They are the same item, £40 quid should cover it and no need to pay carriage. The bonnet won't fit in the back of the coupe though!
        As David said there may be a couple of other items needed as well but these can e found from the same car. If you are lucky the colour might match and then you need to spray the outside only!
        David
        • Stick Insect
          • Dec 2003
          • 2338
          The lights might be covered slightly by the newer wider grille.
          If the later lights are fitted to the 89 bonnet ( same as yours and mine) there is a bit of a gap between the bonnet and the edge of the lights.
          David
