Aero Wipers
  • blu_s2
    • 392
    Aero Wipers
    Just tried to fit the new aero wipres and ran into a little bit of a snag.
    The driver's wiper fouls the bottom of the windscreen, or more accurately the rubber that overlaps the rain gulley at the bottom of the screen.
    It is the wiper's spring clip that fouls the rubber and unfortunately its a bit too violent a rub to live with as it would destroy the rubber and then start on the gulley very quickly.
    Has anyone else found this and is there a BTDT?
    PS. bending the arm was definitely out as I'd have to bend it about 30degrees to avoid it rubbing.
    Jim
  • Doug_RS2
    • 3847
    Mine rubbed but a very small bend, stopped this.
    You can see in the pic that when it rubbed it stopped the centre of the blade touching the screen at the bottom position.
    • blu_s2
      • 392
      Doug, where did you put the bend? I cannot see where I can bend the wiper arm to stop it?
      Jim
      • Doug_RS2
        • 3847
        I bent it where the green arrow is pointing to.
        • blu_s2
          • 392
          Doug, thanks. Done although from the photo mine needed a *lot* more bend than yours.
          Jim
          • fendent
            • 145
            • Country: Switzerland
            I too have ordered Aero wipers. Mine will be from a 2002 A6. The wiper on the passenger side is a bit too long and it touches the A -pillar.
            The wiper arm for the driver side has not arrived yet. I will make pictures of it when mounted.
            However I did not manage to upload pictures to the forum in the past.
            When looking @ the posted pictures it looks like the blades are mounted on the old arms. Is this correct?
            Marcel
            Marcel
            ________________________________________
            current: RS2, + A2 TDI 3L
            Favourit: Coupe Quattro Typ 85 or 859. I had one.
            If you know someone in Switzerland selling a Ur-20V --> tell me.
            • Doug_RS2
              • 3847
              They are new arms as well. The kit of parts for this from vagparts uses one lupo arm IIRC(might be a lupo blade) so the blades don't touch the A-pillar.
