Anyone ever had any water dripping in and building up at the rear hatch's inner card and when you open the hatch,water is dripping out from the locks?
I noticed that with mine.What happens is that no water is coming into the car.BUT when i open the hatch,i get water dripping off the locks of the hatch and the hatch trim at the bottom,and if i open the hatch fully the water glides down over the plastic pillar.
I can only imagine 2 ways in for the water.
1) the rear lights,although they seem very dry and give no signs of leaks
2) over the top 2 corners of the rubber sealant,the rubber comes very close to the plastic pillar of ther hatch,and there might be a possibility of water or droplets coming in the car and slowly gliding down and gathering up behind the trim.
Now i got me some silicone and sealed the 2 upper corners,as well as tried to calibrate the hatch by manipulating the screws on top so as to have a better closure,but im uncertain if i have found the source.
Anyone else has had any leaky rear trim or sorts,to give me a few pointers?
cheers
vasilis
cheers
vasilis
