Coupe Lower Trims
  • MikeLarwood
    • Aug 2008
    • 278
    Coupe Lower Trims
    Morning,
    Any idea how the f**k I get the lower trims on the rear quarters of the Coupe? Don't say slide - I've tried time, and time, and time again. With no joy. And how do you fit the front wheelarch trim things on the bottom of those?
    Thanks,
    Mike
  • Fat Audi 80
    • 10547
    The trims on the lower REAR quarter panel slide towards the rear wheel.
    Spray lots of wd40 behind them and then PULL!
    They will be tight as the chances are the plastic guides that hold them on have gone a but rusty where the mounting screw bolts to the body.
    They will come off, but you *may* break the clips. New clips make re assembly much easier.
    As for the front, I *think* it screws on somewhere, but I have not replaced these on my car.
    Good luck.
    Cheers,
    Steve.
    The Perfectionist
    • rs2coupe
      • Oct 2004
      • 1782
      • Home: Trinidad and Tobago Current: United States
      Originally posted by MikeLarwood
      Morning,
      Thanks,
      Mike
      Sorry but they are made to slide off and on. One or some of the clips they slide onto is off center and is causing the moulding to get stuck. Carefully fiddle it up and down as you try to slide the moulding off.
      Had the toughest time with my front ones too, just had the shop do it.
      Cheers mis amigos,
      _Anton
      • Jas11n
        • 5067
        Open the door. Get a plastic mallet and "gently" tap the trim back from the front leading edge.
        Like Steve says, if they've not been off for years, they'll be really stiff to start with.
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • MikeLarwood
          • Aug 2008
          • 278
          Nah, I've got them off! I just can't get them back on! For the life of me!
          • Fat Audi 80
            • 10547
            I suspect you may need new clips (if you don't already) the old ones are likely to be Fubar'd...
            Slowly slowly catch the monkey...
            HTH
            Cheers,
            Steve.
            The Perfectionist
            • rs2coupe
              • Oct 2004
              • 1782
              If its not the clips getting mashed then it's the guides on the moulding themselves being twisted out of shape
              Cheers mis amigos,
              _Anton
              • vonbeck
                • 2455
                much easier to do do this with
                1 new clips
                2 when its warm as the plastic trim is alot more malleable!
                :mischeif:
