Towbar
  • madpugger
    • Sep 2007
    • 1901
    Towbar
    Does anyone have a genuine removable towbar on their avant? I have managed to get hold of one but I am not convinced it is specifically for the S2 as it requires the bumper to be cut. Is this correct?
    Mike
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
  • raymor
    • Sep 2003
    • 597
    Mike,
    If it's my old one, then it is specifically for the S2 Avant. It's perhaps not OE specific in that there needs to be a 15mm x 40mm nick taken from the rear bumper. But then it was only £250. I guess the OE ones cost a little more than that.
    HTH
    1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
    1987 CQ85RS
    1994 S2 Avant- Gone
    1991 V8 -Gone, but lives on in the TDi and CQ
    Fintray Hillclimb - 33.20s
    Doune Hillclimb - 55.02s
    Forrestburn Hillclimb - 52.61
    • skiffy
      • 136
      Towbar
      I had a factory fitted removable towbar on my S2 coupe years ago which needed a hole cut in the bumper, so sounds normal.
      Wonder where that car is now, J708 NDV anyone?
        I've got an OE Westfalia one on the coupe, its invisible when the ball is not fitted. I had to cut out the bottom of the bumper, the cutting marks were there inside the bumper when I took it off
          • rs2coupe
            • Oct 2004
            • 1782
            • Home: Trinidad and Tobago Current: United States
            any pics of it fitted and the cut you made John? I just paid for an OE one. I wonder if when I put the rs2 rear bumper on if cutting is still necessary.
            Cheers mis amigos,
            _Anton
              pic in post above
              also in this thread
              Click here
              • GT500
                • Jun 2006
                • 2181
                Mike
                I've just fitted an S2 genuine one to my RS2. Had to cut the bumper. both inside (to gain enough room) and the bumper.
                ALOT less than newsh!
                I made a panel to fill the hole when not in use
                I'll take a pic tomorrow.
                I swapped it for the one I made from a genuine coupe bar. If anyone wants a removable avant one its tried and tested! Only swapped as came across the new one!
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                • madpugger
                  • Sep 2007
                  • 1901
                  Originally posted by raymor
                  Mike,
                  HTH
                  It sure is your one I was just curious as to whether Audi had one for an 80 and one for the S2/RS2. I have your old bumper too so I don't have to cut mine, but the colour match is not that great, I think you must have the darker shade
                  Le Mans 2012
                  Nurburgring 700
                  1995 S2 Avant
                  • raymor
                    • Sep 2003
                    • 597
                    I think that and the tailgate were the the only undamaged panels IIRC . Still if you're going to do something....
                    1987 CQ85RS
                    1994 S2 Avant- Gone
                    • madpugger
                      • Sep 2007
                      • 1901
                      I was surprised at how well it looked actually. I am going to get the bumper painted soon along with my tailgate which is starting to go below the wiper.
                      Le Mans 2012
                      Nurburgring 700
                      1995 S2 Avant
                      • mundo
                        • Aug 2006
                        • 36
                        towbar
                        GT500, I presume you bought a removable Westalia bar for the S2 avant? if so where did you get it from and does it need modifiying for the RS2?
                        love to see a pic of your cut / panel
                        ..how many £££ for your old one?
                        Thanks
                        Simon
