The boot lock on my coupe has failed. It won't open with the key or central locking.
Part of the lock body has sheared off where it connects to the latch release rod.
Pulling the rod from inside the boot gives the unlocking sound but it still fails to disengage. Possibly because I need to pull the rod a little bit harder.
I'm also wondering if anyone has a procedure (factory or DIY) on how to swap my lock cylinder/tumbler into a used replacement? Even if I could swap over the broken lever that may simplify things further still.
Does anyone know if you can use a boot lock from a car with a factory fitted alarm in a car which doesn't have this installed?
In other words can I replace 895 862 055 with 895 862 055 C?
I reckon it is possible by removing the microswitch mounting bracket should be enough. I'd be interested to hear if there are any BTDTs on this too?
Whatcha got?
Whatcha got?
