Hello
Can anyone help please? I have a '91 3B Coupe. The bonnet release mechanism seems to have jammed. When the interior leaver is pulled, it travels all the way, but bonnet will not release. It seems to be retained on off side. Has anyone any suggestions for accessing this cath, behind the off side headlamp. Please bear in mind that I cannot remove lamp (no access to top srews - under bonnet!) I have tried to access from below, by removing just undertray, but unsuccessful. I need to access uregently as there is problem with cooling system, so need to top up and sort out.
Ian
Ian
