I mounted an RS2 bumper to the front of my CQ, and in doing so I removed the USDOT bumper shocks that hold the original bumper on. On the right side shock, there is a threaded hole that is designed to screw in a cable with an eye on it for towing the car.
I know the right side mesh for the RS2 bumper has a special thumbscrew that allows you to remove the mesh from the outside, unlike the other two mesh sections that are screwed into the bumper from the back. I assume this right section is removable like that for towing, but what provision does an RS2 have for towing?
I mounted the bumper using RS2 brackets, but they don't provide anything to tow with. What do S2's and RS2's have in the way of a place to hook onto for towing (or cinching down the car when flatbedding)?
Thanks,
Thanks,
