Anyone got an how-to remove sunroof
  • lind4hl
    • Jul 2008
    • 2465
    as topic, i am going to remove mine and cover it up with some nice Carbon fibre plate or something.. can i take it out without removing the headlining??
  • mcandmar
    • Apr 2004
    • 5118
    On a coupe yes, havent taken apart an avant one. The interior trim panel unclips from the sunroof and will slide back, you will then be able to get at the bolts holding the panel on. Unbolt and lift out from above. From memory you have to do it with the sunroof in the raised position.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • lind4hl
      • Jul 2008
      • 2465
      so interior trim slides straight back in lifted position and then its just to unbolt and lift it out on the top?
      • mcandmar
        • Apr 2004
        • 5118
        Think you slide back the interior panel first. Give me 2 mins and i'll find the manual and double check.
        • lind4hl
          • Jul 2008
          • 2465
          sure
          • mcandmar
            • Apr 2004
            • 5118
            There actually different from coupe to 80/90 bodys. I've attached a pic as its easier than trying to write it out...
            • lind4hl
              • Jul 2008
              • 2465
              hmm i think i will sort it out
              Thank you
              • mcandmar
                • Apr 2004
                • 5118
                Coupe version..
                • K Simmonds
                  • Dec 2007
                  • 7627
                  You need to take the headlining out of both Coupe and Avant to remove the complete sunroof assembly. Which is what I assume you want to do in order to save weight, I'm considering removing mine for this reason.
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • lind4hl
                    • Jul 2008
                    • 2465
                    doh
                    yep. it is for saving weight.. anyways, then i can take out some sound deadening from there also..
                    • mcandmar
                      • Apr 2004
                      • 5118
                      Ohh you want to remove the complete unit. In a coupe the frame is held in with a bunch of bolts around the frame, couldn't be easier. Removing the headlining without damaging it takes time. This thread might be of interest http://www.s2forum.com/forum/showthr...ght=headlining
                      • quattro84
                        • Mar 2006
                        • 947
                        I did it for an 80 sedan not long ago because the rubber was full of algue 'n stuff (manual operated OEM sliding/tilt roof). Replaced it with a felt-rubber from an 1303 VW Beetle
                        Only interiour part i removed was the operating handle, and ceiling light to get to the screw that holds the plastic cover on the ceiling. Then you can access the 2 screws covered with lock-nut that hold the operating gear that moves the slidercables.
                        Then i slided the roof back as far as possible.
                        I removed all screws visible from outside (except 2 black countersunk ones that keep the sliders together) and then you can lift the entire assembly out (put some masking tape on your roof to avoid scratches)
                        Then i put the handle back on to put the roof in tilt mode to get the new rubber on. You can take the 2 sliders off with the spiral cable in place (Watch out for the 2 black 'flaps' on the side! Put those back in de sliderrails before mounting, otherwise it will not fit back). It is a pain in the @ss because if you operate it outside the car the cables will twist the slider assembly!
                        Reassemble the roof in reverse order and watch out because the operating gear/sprocket has a kind of 'memory'. It counts the number of revolutions internally so you can't damage the roof when opening. When you mounted the roof back in place you have to put it in closed position. Then you take out that gear with the handle on. The handle has a button you press when you want to put it in tilting mode. Rotate is till it blocks (this means that this position marks that the roof is closed) and mount it back in.
                        That last step took the most time to figure out what the right position was. Every time i closed the roof till the handle blocked, i noticed the roof was a bit too far open.
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          Yep, thats how the sunroof pannel is removed, the ONLY way to remove the runners ect is to drop the headlining.
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • lind4hl
                            • Jul 2008
                            • 2465
                            why cant anything be easy on these cars
                            but i love ´em anyway
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              Removing the headlining is not to bad a job if you go about it systematicaly, refitting can be a bit of a PITA, again patience is all that is required. Once the headlining is out the way it's really easy to get the complete sunroof mech out, 8 X 13mm m8 bolts and a wiring plug, if my memory serves me correctly. If you take the whole lot out this way it's striaght forward enough to refit in future. Having another pair of hands to help is recomended.
                              1994 MTM RS2.
                              2000 B5 TQS.
