avant rear lights clean look
  • Nuvo
    • Nov 2003
    • 3825
    Hi Dave, I didn't attempt to fix the broken link but I believe this is the thread you are looking for:
      • Dec 2017
      • 5987
      Excellent. Thanks very much
      • david1980
        • May 2014
        • 1025
        look on the handle, you will see a line in the cast that you can cut down (that is what I did on the few avants i've done in the past)
          • Dec 2017
          • 5987
          Cheers.
          I have cut the handle no problem. My issue is that the idiots who painted my car have set the outer rear lights in panel bond
            • Dec 2017
            • 5987
            I have given up trying to fit these. Now available if anyone is interested.
            • mdz
              • Jun 2012
              • 775
              • Country: Latvia
              #21
              Alternative option is to fit handle from c4 a6 avant
              I'd just smash the standard lights out and carefully cut off glue to fit these.
                • Dec 2017
                • 5987
                I just couldn't bring myself to do that
                  Yep, needs to be done
                  • mdz
                    • Jun 2012
                    • 775
                    • Country: Latvia
                    #24
                    I know the pain of breaking something on your car even the part is cheap. But sometimes it is worth it.
                    • david1980
                      • May 2014
                      • 1025
                      Always look on the plus side, if the lights are bonded in that well you should not have any leaks hopefully.
