Got stuck in a Hotel car park with no power to windows/sunroof last week. I have an intermittent fault shortly after start up. I assume its the relay
"443 919 578 J". Local stealers want £49.32. I understand its common to the older 80/90/coupe models. Any alternative source apart from breakers? Thanks James.
from memory (which is always shaky) there are two plastic tabs, to be depressed to pop the cover off. then you'll see the printed circuit board, all soldering is on one side.If you're at Billing we could look there?
It's the double width relay behind the steering wheel (above the auxillary wiring).
I also have the same problem and am trying to locate the relay. When you say behind the steering wheel do I remove the steering column cover or the cover/storage shelf below the steering column by the footwell ??
