80 Central locking question
  • 80 Central locking question
    Im gonna stick remote locking in the 80Tdi (amazing how 2 or 3 sec in pissing rain sticking a key in the lock can annoy u!) and wanted to know, because of the air system, do i need to get a single actuator to drive over one lock to then operate the pump?
    many thanks
    AL
    You used to be able to buy a kit that plugged straight in from vagparts, you could also look at a4's as they use a remote central locking kit that should fit providing the c/l pump is the same
      Hmmmmm so the universal kits are not suitable? Sh*t! thought the pump might be a prob but thought i could just maybe use an actuator on say the drivers door to triger the existing central locking?
        I'm not 100% sure how usefull they are, I know jas tried one on project sooty and said that he had problems with it getting hot.
          The universal ones work, I have used a couple of the rclick ones, cost £30, value for money pretty good and easy to install.
          http://www.rclick.co.uk/product_info...roducts_id=671
          Think that is the one Jason had, there is a thread about them on audifans.
          Sold ABY-stock
            Really? hmmm well since this is for Sooty2, i may investigate further. might pick one up na have a play with it anyways there only bout 15 quid. Cheers!
            AL
              Are these easy to install (92 3b with manual central locking) for an electronic numpty like me?
              1992 3b S2 Coupe
                Nope. I managed and I dislike electronics.
                Step by step guide in this thread about half way down.
                http://audifans.net/ftopict-24076-remote.html+locking
                Sold ABY-stock
                  Had Actuator as an interface on the suzuki when I got it, used to routinely blow fuses up in the dash because of the two systems working at cross perposes.
                  The 90, 100, S2, are directly wired as it really is a sinch. The Suzuki is now too.
                    hmmm does look like something i might actually be able to do
                    Will get the looooooooooong list of more pressing things ticked off then head for this I think
                    Cheers for the linky too
                    1992 3b S2 Coupe
                      I have forgotten my keys on the door 2 monhs ago .... I like it and may be I will try this ...
                      Thanks for the link
                        Put a Scorpoin Alarm purchased from Ebay in my fathers Pajero, I was mightilly impressed with the quality and how easilly it tied up to the CL. I think once ths S2 runs again I may well be changing the useless and irritating fob immobiliser for one. Might even do the remote boot release
