New Wing
  • dhali7376
    • Nov 2009
    • 301
    New Wing
    When replacing a new wing with a genuine Audi part is it necessary to coat the inside of the wing with any sort of protection?? If so, any particular product that stands above others??
    TIA
  • rj scotty
    • May 2006
    • 2195
    TIA
    I always stone-chip and paint the inside and anywhere else that ain't visible, I'm an amateur though. The more professional body-workers on hear may have different ideas.
    cheers
    rich
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • shaun5
      • 1610
      The new wing probably wont have a hole in it for the side repeater so you'll need to drill it before you paint it
      • dhali7376
        • Nov 2009
        • 301
        cheers
        rich
        would it be a good idea to use some sort of wax coating too?
        • dhali7376
          • Nov 2009
          • 301
          will the holes be there for the side strips or will i have to drill those too?
          • john johnson
            • Jun 2009
            • 190
            Ask gt500 on here regarding proofing, I had a pair of new wings fitted to one of my ur's last year and they seriously went to town proofing them with a factory spech product then painted the wings off the car, but they were £1300 just fir the wings so I deffo wanted them proofing!
            3 Urs to keep , 95 Avant,
            shedmeister
            http://s159.photobucket.com/albums/t144/jsquatts/
            • dhali7376
              • Nov 2009
              • 301
              thanks AGAIN John
              • Al Wyn
                • Nov 2006
                • 3746
                Dal make 100% sure when you order that they order RS2 rhd wings... S2/80 avant wings have an oval Audi badge hole low down and lhd will not have the indicator holes. Pm Rob GT500 he will be able to advise
                S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                  Audi RHD wings will have no indicator holes also, you have to cut them in.
                  • shaun5
                    • 1610
                    the holes for the trim should be drilled, mine were. You will need the captive nuts that go on the lower, front of the wing.
                      RS2 and Coupe wings are different
                      • dhali7376
                        • Nov 2009
                        • 301
                        thanks Al, made sure they were RS2 as i was looking at the Etka screen as he was sourcing the part numbers.
                          From the man from Audi http://www.s2forum.com/forum/showpos...9&postcount=17
                          • dhali7376
                            • Nov 2009
                            • 301
                            any speacial tool required? or just a a reasonable sized bit and a file??
                              Of that I do not know unfortunately, I'd ask GT500 and S2avant as I'm sure they would know
